connect error using SQL connect
Hi, I am unable to connect to the data source name I have created. Each time I get a -4 error connection error with a hex code of xFFFC. Any help with this or an explanation on how to add values to a Access database using SQL would be appreciated.
(2,985 Views)
hi there,
please post some code.
in the meantime: visit http://jeffreytravis.com/lost/labsql.html
there you can download a well working ADO - interface for ODBC datasources which allows you to execute SQL - statements (examples are provided). the interface is written in LabVIEW using the MS-ADO ActiveX automation.
best regards
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(2,978 Views)
Thanks a lot the website you put helped me out.
(2,969 Views)
