connect bluetooth client (Android phone) to VI server
"This block diagram actually works?"
Which block diagram? 🙂
If you read the above posts, you should know that I only managed the communication back and forth using a virtual COM port
mapped to the bluetooth adapter, not using the native BT VIs.
Actually, after you map a COM port to your BT adapter, it is very easy to communicate with it using simple serial communication protocol.
I also use the same approach to communicate between my smart phone BT and my laptop running a C# application. Same way as in LabVIEW.
I linked it above , but I put it here again for you, this works without any problem:
https://forums.ni.com/t5/Example-Code/LabVIEW-Android-comm-via-bluetooth-serial-using-LabVIEW/ta-p/3...
Message 11 of 11
(445 Views)
