configuration parameter interface
Hello .
   I have just finished my main VI.  But I realized that an  Initialzation Interface should be add to my system.   I mean that when the VI start,  a window will pop up   for configurating parameters and  pass parameters to the main vi. What I thought that using a sequence structure and p...
   So if you have any advise ,please tell me.Thank you very much.
(3,245 Views)
Absolutely no need for any sort of sequence structure. Your pop-up will pass the parameters so dataflow will be enough.
(3,237 Views)
   Maybe i haven't expressed this question clearly. The question is how to pop up a window for configurating parameters and pass parameters effectively to the main vi. And the main vi in the picture is just a sketch map,  in fact I haven't package the source code in to a vi,it‘s a relatively large program.
(3,230 Views)
Look at the examples. A pop-up is just a VI with the display properties set to show front panel when called. You wire the indicators on the subVI to the connector pane.
Your comment about packaging the source code to a VI makes no sense. Source code IS a VI.
(3,225 Views)
