conditional case
thanks again.
Your second sentence sounds correct to me. In both case, A happen before B. B will not happen as long as A is OFF.
 2 possible case
a) A is ON, then OFF. it is subsequently followed by B ON.
b) A is ON , then B ON.
Both case, the output will be ON as soon as A is ON, then output off as soon as B ON.
Appreciate your help.
regards.
Message 11 of 13
(768 Views)
Hi Heang,
So, are you all set now?  If not, what is the additional behavior required?
Howard
Message 12 of 13
(761 Views)
thanks
It works eventually.
I get what i desire from the output.
Truly appreciate what you all have helped me.
Your suggestions really widen my knowledge on Labview as i am still novice of Labview.
thanks.
regards.
Message 13 of 13
(746 Views)
