concatenate strings from pattern matching
hello guys!
i was working on a alphabet sign language recognition. so far i am able to recognize alphabets. i would like to output a text indicator whenever there is a match if possible i would like it to become a word.
i got a vi from https://www.youtube.com/watch?v=RlECSKpIsbw that recognizes a pattern from a template and i have just replaced the template to an actual image of a, b, and c sign language and added some led indicator. for now i only have templates for a, b and c since it would just be the same i would just add the other alphabets later on. i would also like to have a reset button that would empty the text indicator. here is my vi after some modification.
thanks in advance guys!
(3,197 Views)
First of all, you should make all of your templates before your main loop.  I recommend making an array of file paths and then use a FOR loop (autoindexing) to create your image templates.  You will then have an array of templates.  Then you use a FOR loop to compare your image to all of the image templates until you find a match.  You can use a conditional terminal on a FOR loop to stop the search when you find a match.  From the match, just use Index Array to get the element you want to add to your string (you will want to keep your letters in an array of strings).  Store your string in a shift register.
(3,189 Views)
