computer restart caused by MAX
I have just upgraded from Labview 7.0 to 7.1, including the MAX upgrade from version 3.0.1 to version 3.1. When I open MAX and click on any of the configuration settings, the computer immediately restarts. I did not have this problem before upgrading. I have uninstalled and reinstalled the software, but this was didn't help. I have a BNC-2120 connector accessory attached to PCI-6052E device which my computer tells me is "recognized" and "is working properly". I am running a Dell pentium III 866mHz with Windows 2000 professional.
Message 1 of 9
(5,271 Views)
Did you uninstall MAX 3.0.1 and all of its sub components before upgrading?
The reason that I ask is that NI-DAQ does not uninstall previous versions before installation. So if you install a new version over top of an old version, then you will see unexpected behavior.
Whether or not this is the case, I think a full uninstallation and reinstallation of NI software would be the fastest solution. While this may take some time, it is better then trying to troubleshoot the issue piece by piece.
Here are the steps that should be followed. Good luck!
Justin T.
1. Turn off the computer and physically remove or unplug all NI hardware that you have installed on your system. This includes anything that is PCI-, ISA-, USB-, 1394-, or ethernet-based.
2. Turn the computer on and go through Add/Remove Programs (START � SETTINGS � CONTROL PANEL � Add/Remove Programs) and remove everything NI-related. Generally, if you can remember, it is best to uninstall things in the reverse order in which they were installed. For example, if you installed LabVIEW, then NI-DAQ, and then the Internet Developers Toolkit for LabVIEW, you should uninstall the Internet Developers Toolkit first, then NI-DAQ, and then LabVIEW last.
3. After everything has been removed (do not be concerned at this point if an item still shows up in the Add/Remove Programs list after you have removed it), close all programs and restart your computer.
4. Go back into Add/Remove Programs. If anything that you removed in step 2 is still listed, write down the entry in the list exactly as it appears. These will be removed by manually editing the registry as outlined below.
5. Go to START button of your operating system, choose RUN and type "regedit". This will open the Registry Editor window. Go to the Registry Menu and choose Export Registry File. Select "All" for the export range, and select a file name. This creates a backup of the Registry in case a mistake is made when deleting the keys.
6. Remove the following registry components from the Windows Registry:
HKEY_CURRENT_USER\Software\National Instruments <-- Delete the entire tree!
HKEY_LOCAL_MACHINE\Software\National Instruments <-- Delete the entire tree!
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Enum\PCI\ or \ISA and delete registry entries containing any keys with 1093 in them.
Do not worry if any of these trees are not listed. If you have Administrative rights, and you still cannot delete these keys, that is also OK. Continue with the remainder of the process .
7. Close regedit.
8. Make sure that you do not have any of your own VIs or other files saved in the "C:\VXIpnp", "C:\Program Files\National Instruments", or "C:\WINDOWS\nidaq" folders. If you do, copy them to a different location. If you are concerned about keeping old virtual channels and your SCXI setup intact, then backup the "C:\WINDOWS\niconfig.daq" file, too.
Delete all folders and files mentioned above!!!
Note: If you have Windows NT/2000, replace "C:\Windows" with "C:\WINNT" in the paths listed above.
9. To be thorough, you can use Microsoft�s Clean Up Utility. Pasted below is a link to this utility and directions for use.
http://support.microsoft.com/default.aspx?scid=KB;en-us;q240116
10. Reboot your computer.
11. You should be ready to install your software. For the cleanest possible install, first install all of your application development software, such as LabVIEW, Measurement Studio, TestStand, etc. Reboot your PC when requested after each install. Now install your driver software and follow the associated user manuals.
12. Finally, shut down and re-install your hardware. When you boot back up, it should be detected in MAX.
Message 2 of 9
(5,266 Views)
I just deinstalled LabVIEW 7.1, I had two error messages when LabVIEW runtime engine7.1 was deinstalling. Error 1721 and then error 1603. After deinstalling the Runtime Engine. I cleaned the registry, like your advise.
Now I reinstalled LabVIEW 7.1. The problem is: when I launch LabVIEW7.1.exe files, LabVIEW doesn't start up. It looks it is blocked.
What can I do?
Joerg
Message 3 of 9
(5,173 Views)
Mr. B,
There are a couple of things that I would check. Can you open the LabVIEW development environment and use it normally? Do your VIs run properly? If so...can you build an EXE out of one that you know works and run it?
Also...check and make sure you are logged in as the administrator though I doubt you could edit the registry if you did not already have admin rights.
Let me know about the VIs.
-Brett
Message 4 of 9
(5,144 Views)
Hi Mr.B
Hi i'm looking for the LabVIEW software a free version ....any version above 6 or 6.1 or 7... u have been using version 7 and 7.1,,...could i know how did u get the software.......!!!!!!!!!! we need it for a project and are unable to find..it...... we are running out of time... and would like to know if you could help us with this...
 I would appreciate you help. If you know some one in this forum or any of your friends you have used or got a free version of the Labview.....could u just email it to me or post anote in this forum...
 thanks
Message 5 of 9
(4,982 Views)
bluerose:
A.      Wrong topic to post in, you probably should have started a new thread entitled " I WANT TO RIP OFF NI SOFTWARE ILLEGALLY"mad smiley
B.      Mr. B. has not been around these parts for over a year and a half, I don't think you'll be hearing from him
C.      NI offers 30 day evaluation packages of software, you may do better off using that in the short term
Message 6 of 9
(4,974 Views)
hi thanks for the info.....ok could i know the website or nethin for the 30 day trial........... could u plz fwd it ot me......and one more thing y  r u so upset about NI software...... and could i know...wht the problem is....
 neways thnks again
Message 7 of 9
(4,957 Views)
Bluerose:
Sorry if I offended you, it sounded like you wanted to acquire software illegally.
Here is a link for a 30 day evaluation version for the latest version, 8.0. I do not know what features are restricted in evaluation mode.
https://www.ni.com/en/support/downloads/software-products/download.labview.html
Here is a link with pricing if you wish to buy:
https://www.ni.com/en/shop/labview/select-edition.html
Good Luck
Message 8 of 9
(4,925 Views)
hi.....
no u have not offended me...actually  i'm a student and i'm loking for the software for a long time now... i jus need a demo version of nethin which is above 6.0 or 6.1...... i have never used LabVIEW before but, trying to get hold of one from NI but cant get nethin
 i did try to download the LabVIEW8 evaluation...but some body jus shut off the pc twice so..i cudnt get it... i dont want it ILLEGALLY..... b'cz i jus need it to test some stuff for my project .. and 30 days would be fine for me,.............
if u do have a full version then
I would appreciate it ..if you could forward the website name and address to me.... i dont require a full version but its always helpful if you hve one ...........
 Thanks again
Regards
Message 9 of 9
(4,916 Views)
