computer crashes when a LabView application is run
I am using LabView version 7 on windowsXP. Computer crashes when a LabView application is run. The event viewer shows error as: The nisldk service depends on the following non-exisiting service: nimxdfk.
The other error that it also shows is: The nimidru service depends on the following non-exisiting service: nimxdfk.
What should I do to get rid of this problem?
(2,628 Views)
See if this post helps.
(2,612 Views)
