composite class
I would like to know if there is a way to automaticaly scan class  of composite class.
or at least obtaining a list of classes used to compose
i tried to add a member vi using "cluster to array" function  but it doesn't work ,
It s a little bit surprising as we can use bundle and unbundle but not cluster to array !
i 'm forced to explicitly transform cluster of classes in array of classes...
after that  i can apply a common method on array
Does anyone know a better way
Best regards
Tinnitus
Best regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,435 Views)
Accepted by topic author tinnitus
nobody ?
Regards
Tinnitus
(3,403 Views)
My french friend,
it is a bit hard to understand what you are trying to ask. Maybe some pictures (uml or lvoop) might help Smiley Wink
I guess you are just touching the limits of what is currently implemented as LVOOP. You could place all classes your class is composed of in an array and place this in the private data cluster. But then you will need to do type-casting or use the preserve runtime class(?) primitive inside a for loop. Sadly LVOOP doesn't support generics (like linked lists of objects that type-cast behinde the scenes).
Also try a cross-post on LAVA, there are some coole LVOOPers there that only occasionally visit this place.
Felix
(3,394 Views)
