complex waveform to bit array
Hi everyone!!
I follow stuck with my thesis.... I need help urgently. I have an array of bits that they are passed by the continuos BB-PSK Gen and I obtain an output complex waveform. This complex waveform contains the I and the Q signal and I want to see these 2 signals in a graph. I can see the signals like sinusoides but I want to see in digital form ('1' and '0'). Any idea??
Attached vi to see better. I want to see the I and Q signals like an array of bits.
Thanks.
Message 1 of 8
(3,363 Views)
Well, you'd have to convert them to digital first. Have you tried a simple comparator operation?
Message 2 of 8
(3,357 Views)
No, isn't a good solution because the graphs that I'm obtaining are the same....
Message 3 of 8
(3,353 Views)
So are you just wanting to see each I/Q value as a binary pattern? If so then I'd suggest using the digial waveform graphs. You can find an example on how to use them in the Example Finder (Help -> Find Examples).
Message 4 of 8
(3,349 Views)
The problem is that I don't have digital values in the complex waveform, I have complex values so I can not use the build a digital waveform.
Message 5 of 8
(3,344 Views)
But you're separating the real and imaginary parts (I and Q). So each of those numbers can be converted to a digital stream for the waveform.
Message 6 of 8
(3,338 Views)
Really? How? I don't find a good example..
Message 7 of 8
(3,336 Views)
You could try something simple, like the attached example.
Message 8 of 8
(3,332 Views)
