comparison between 2 arrays
i want to check if 2 arrays are equal or not ,as being equal is the condition of while loop to stop.
(3,113 Views)
Wire the arrays to the two inputs of the "equal" comparison operation and the output to the stop terminal of the while loop (set to "stop if true").
(3,111 Views)
i have done this but an error occurs data type mismatch
(3,103 Views)
Then post your VI so we can see what you are trying to do and offer specific suggestions.
(3,101 Views)
The default output of the Equal? operation when you wire arrays is to give you an array so you can see the comparison for each and every element. To get a single Boolean output right-click on the Equal? function and select Comparison Mode -> Compare Aggregates.
(3,085 Views)
