compare two arrays
Hi, is there anyway you can post this except for labview 2013??? I can't open your 2014
Message 11 of 20
(2,586 Views)
Use the version conversion forum board for such request (download the VI and post it there):
http://forums.ni.com/t5/Version-Conversion/bd-p/VersionConversion
Message 12 of 20
(2,553 Views)
You can't recreate the code from my image?  Try it.  You might learn something in the process.
Message 13 of 20
(2,511 Views)
I've been playing around with this for a while now, but is there a way to do the exact same thing except with numeric arrays instead of string arrays??
Thank you!!
Message 14 of 20
(2,465 Views)
For integers, you simply replace the string constants. For floating point numbers, since you shouldn't use an equal comparison, use the In Range and Coerce function. Post your code if you are still stuck.
Message 15 of 20
(2,450 Views)
Do you mind posting a small piece of code illustrating what you are saying. I'm not completely following you...
I would like to use floating point numbers and integers.
I've attached the code that I have done buttt...they changes I have made takes away the main functionality of the code (see the original post for the discussion). I need my program to do the same thing, except with numbers!!
Message 16 of 20
(2,441 Views)
You are very close.  Change your Corresponding X's to be a 1D array.  The constant initializing that shift register should also be a 1D array of Double.  And then inside of the case structure, you need to specify column 1 with the Index Array.
Message 17 of 20
(2,425 Views)
Hey Crossrulz (or anyone else lol),
   Can you take a look at the attachment and see what I'm missing?!?!?!
Message 18 of 20
(2,399 Views)
I think you mean to index out the second column in your for loop (not the first column)
Message 19 of 20
(2,389 Views)
Fo anybody in the World who may need this...here you go!!
THANK YOU SOOO MUCH TO EVERYONE WHO HELPED
Message 20 of 20
(2,377 Views)
