compare two 2d arrays and make 3rd array by bigger numbers
Dear Friends,
I am new in Lab view and trying to develop one of my first codes, I have 2 2d arrays which I would like to compare them and make 3rd array by bigger numbers,
 1st array: 2 5 9
                 3 5 6
2nd array: 8 9 1
                 1 3 8
final array: 8 9  9
                  3 5  6
any help or suggestion from your side would be highly appreciated.
Best regards
Arvin
(3,475 Views)
Accepted by RavensFan
Look at the Max and Min function in the Comparison palette.
(3,471 Views)
Thanks for your reply
Third array should be in the same size of two array and I would like to compare them element by element, That function gives me only the max and min
(3,415 Views)
Accepted by topic author arvin1947
Did you try it?
RavensFan has the right answer.
(3,412 Views)
You can certainly compare element by element if you put it into nested For Loops with auto-indexing turned on.
But that is not necessary as the function can take scalars and arrays of various dimensions as Taki showed you in his snippet.
(3,402 Views)
Thanks so much 🙂
(3,382 Views)
