compare elements
How do I comare elements in an array and output a T/F?   I want to stop my while loop IF two elements in the array are equal.
Eric Yuzon
Senior engineer
ERC
Walled Lake, MI 48390
ericyuzon@e-reman.com
e-reman.com
Message 1 of 15
(6,337 Views)
Accepted by topic author bteed@dormanproducts.com
Like this with a equal and OR Array Elements function. Make sure the Equal function is set to compare elements and make sure the data type you are comparing is an integer type.
Message 2 of 15
(6,327 Views)
what is the second compare?  i cant find it?
Eric Yuzon
Senior engineer
ERC
e-reman.com
Message 3 of 15
(6,317 Views)
OR Array Elements like I said.
See the 'Search' button on the Functions palette? You can use that. It also seems that you are using LabVIWE 2009. That image is a 'snippet'. You just have to drag it to a block diagram.
Message 4 of 15
(6,309 Views)
I found it!   Thanks!
Eric Yuzon
Senior engineer
ERC
e-reman.com
Message 5 of 15
(6,300 Views)
Now my next question is related but more involved.   How do I do a bitwise compare within the element?   Maybe a bit mask of some sort?
Eric Yuzon
Senior engineer
ERC
e-reman.com
Message 6 of 15
(6,293 Views)
Yes, you can use a mask..
I'm a little confused...  Do you want to implement that as part of the code example Denis provided?  Or is it a different topic?
Message 7 of 15
(6,289 Views)
The code works for the hex compares.  Now I have to use the same code modified for bit compares.  How do I implement a bit mask?
Eric Yuzon
Senior engineer
ERC
e-reman.com
Message 8 of 15
(6,272 Views)
Here is an example of how to do several things concerning bit masking.
18499iC28F61102189BA7D
- tbob
Inventor of the WORM Global
Message 9 of 15
(6,261 Views)
You simple AND them together..
Message 10 of 15
(6,259 Views)
