compare condition help?
hi i want to make conditions:
if the input greater from 0  then simulation works or on
but when input less from 0 then simulation dont works or off.
can you help me to make this conditions?
tanx
Message 1 of 8
(3,945 Views)
Your question is not clear, and I don't know what that VI is supposed to show.
Are you looking for a simple case structure?
Message 2 of 8
(3,934 Views)
Excuse me for saying it, but your question is pretty silly. The only real input you have is the Boolean and if you don't want to do the simulation, all you have to do is put the function inside a case structure and wire the Boolean up to that.
It also strikes me as pretty strange that you have been using LabVIEW for over a year and have not grasped some of the basics.
Message 3 of 8
(3,933 Views)
how about this conditions:
if value between 10 - 11 then simulation running
but
if value not between 10 - 11 then simulation not running?
Message 4 of 8
(3,910 Views)
Then use In Range and Coerce on the comparison palette.  The boolean output of that would be wired up to your case structure.
You will just need to define whether the limits of the range (10 and 11) are included in the range or excluded from the rang.
Message 5 of 8
(3,907 Views)
can you help me fix my vi?
please
Message 6 of 8
(3,904 Views)
See attached.
As Dennis said, you really do seem to struggle with some basic LabVIEW concepts for someone who has been on the forums for over a year with numerous posts and questions.
Have you taken LabVIEW Basics course?  Have you gone through the free online tutorials? I would recommend you learn more about LabVIEW from here. How to Learn LV
Message Edited by Ravens Fan on 07-29-2009 11:34 PM
Message 7 of 8
(3,897 Views)
Fixed VI Smiley Wink
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 8 of 8
(3,896 Views)
