compare between strings
simple question :
I can't find a function that parallel to strcmp in C language .
How can i compare between two strings ?
Thanks for your help .
Message 1 of 11
(7,783 Views)
Which kind of output you want? (I don't remember what strcmp actually does)
Message 2 of 11
(7,785 Views)
true / false OR 0 - if match != 0 if it doesn't match .
Message 3 of 11
(7,779 Views)
Hello asaf,
there's a hugh amount of comparison functions in the comparison palette. Just try them!
Message 4 of 11
(7,776 Views)
If all that you want to know is if two different strings are equal, use the Equal? function.
Message 5 of 11
(7,772 Views)
I though it is only arithmetic comparisson .
Message 6 of 11
(7,765 Views)
Under Libraries<< Formatting and I/O Library<< String Manipulation there is a 'CompareStrings' function that will do the comparison you want and you can even set it to be case sensitive or not.
Good luck,
TT
Message 7 of 11
(7,748 Views)
Which of course is in CVI but since the question was made to the LabVIEW forum, I think the poster was asking for the LabVIEW equivalentSmiley Wink.
Message 8 of 11
(7,742 Views)
Hai,
        I would like to compare string in two files and extract the word which is same in other one file.
       please mail me if you can help me.
       siva_shiva@sify.com
Message 9 of 11
(7,679 Views)
You can compare, strings, numerics, arrays and even clusters
Message 10 of 11
(7,592 Views)
