compare and search array
Hallo
I have to compare a input data and the ideal data. so far i have understood how to do comparision but the problem create when ideal array have same element with different respective value , similarly input dat are appears to be also same but while doing search in final output array  in 3 column looks different than as it should be.
hope you understand my problem
thanking you
BR
kalu
(3,187 Views)
Hi Kalu,
Check the attached VI. Let me know if it helps.
Nitz
(Give Kudos to Good Answers, Mark it as a Solution if your Problem is Solved;))
(3,172 Views)
thanks for reply but it is not what i want. the process is same as in 1st  vi but , i need the value of input data and ideal array side by side ,comparision of whole array doesnot sound good  beacause i need all element of array as output side by side
best regards
(3,158 Views)
Accepted by topic author kalu
The search array function will stop its search when it encounters a first similiarity.Thst the reason you are getting 500 for all the 'E' s
I have attached a draft .There are still elegant ways to do what you want to achieve.
(3,144 Views)
thanks nijams you solved my problem
Best regards
kalu
(3,137 Views)
