compactrio web server issue
i have a problem with compactrio webserver
i have configured everything but i cant see the front panel in browser
the message is "Server does not supprort Remote panels"
I am using labview2012
Please helpme to configure the webserver
if anybody have a Step by step instruction pls help me
(2,858 Views)
Have you seen this document? https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9zJSAS&l=en-US
Run through the possible reasons for the error and see if any help. If nothing helps can you please describe your system and which cRIO you are trying to connect to? It may be worth adding a MAX technical report to your next post so I can see everything that you have installed.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q0000019hceCAA&l=en-US
Patrick H | National Instruments | Software Engineer
(2,816 Views)
