08-09-2005 04:07 PM
08-09-2005 05:05 PM
08-09-2005 09:36 PM
What datatypes are you storing? Using the wrong datatype can cause all kinds of size problems--as in the datafile expanding at a rate several times the size of the data you're putting in it...
Mike...
08-10-2005 09:59 AM
Thanks for the input.
THe tables in the mdb will contain a string plus up to 100 singles, or a string plus 4 doubles plus upto 48 longs. There may be up to 100 tables or more in the one mdb.
I want to compact the file from the labview exe without having Access installed on the computer. I would prefer as well not to need to run visual basic or other language then labview to do it.
Ron Larson
