communication between VIs !
Good morning
from my vi, can I show my results in other vi ???
(4,526 Views)
Good afternoon
Yes, you can!
(4,524 Views)
tell me how please !! if there is an example i'll be thankful
(4,521 Views)
The most common solution is to send a result as output so you'll get a wire with the result, just like the Add function has two wires in and one wire out with the result.
R-click the top right icon in the fron panel window and select Show Connector to create wire in's and out's.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,516 Views)
Accepted by topic author za3im_ensa
Check out the connector pane: here and here.
Once you've read this you should have cracked it, however, if it's stil not clicking, read it once more, then play around with what you've learned in LabVIEW!
In case I don't hear from you again, good morning, good evening and good night Smiley Tongue
(4,512 Views)
Here in Morocco we are in the morning 😛
any casen tkx for the help 😄
(4,510 Views)
