comment je peux fixer le diagramme d'enregistrement des valeurs chaque jour
Bonjour,
comment je peux fixer le diagramme d'enregistrement des valeurs chaque jour indépendant de celui précedant entre 00h00 et 23h59 ??
cordialement,
Marmara
(2,971 Views)
how I can fix the recorder chart values every day:
how I can fix the recorder chart values each independent one day before between 00:00 and 23:59 ??
best regards,
Marmara
(2,968 Views)
Hi marmara,
Can you rephrase your question? It is not clear (to me) what your exact problem is…
And maybe you should also show a picture to explain your problem:
- There is no chart in your VI (just a XY graph).
- I don't want to wait till midnight to see what you are talking about.
- What do you mean by "before between"?
(2,957 Views)
Hi GerdW,
i mean in the XY graph i want to see the recorded values but not every time just each day independent,
in others words when i record the values for example today the next day if i want to show my graph again i will have in the X axes the date of yesturday and continuously tha times of detecting values of today!!
What i want is to record values and display them but each day a part in the interval [00h00 , 23h59] ??
it is clear now or i shoud explain more ?
best regards,
marmara
(2,950 Views)
Hi marmara,
you you want a fixed X axis from 00:00 to 23:59? Put each days data into it's seperate plot!
(2,945 Views)
