? command to do a print-screen from LabVIEW?
Is there a way to do a print-screen (usually done with control-printscreen from the keyboard) using a command from within labview.
I have a customer of our product that finds it useful to do a print screen of the test panel.  I'd like a way to automate it.
Message 1 of 13
(10,783 Views)
vi methods -> Print.PanelToPrinter.  You can also set the print properties using a property node for the vi.  Also look at application menu item APP_PRINT_WINDOW.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 2 of 13
(10,775 Views)
Hi Test Engineering Leader,
you can use the function from user32.dll (keybd_event) to simulate key down and key up. Use this if you want to print an other application.
Mike
Message Edited by MikeS81 on 02-21-2008 08:11 AM
Message 3 of 13
(10,772 Views)
Hi Test,
easy solution: you can set the vi to "print when panel closed" in the vi properties!
Other solution:
there's an invoke node method that will give you the actual front panel as graphic data which can be saved using the picture file functions. (Instead of printing I prefer to save PNG files - paperless office Smiley Very Happy)
Message Edited by GerdW on 02-21-2008 03:11 PM
Message 4 of 13
(10,770 Views)
WOW!
Three DIFFERENT and ALL useful answers!  (ALL in 5 minutes too!)
( I don't know how to publicly rate a thread, but this rates VERY high in my book! )
Message 5 of 13
(10,756 Views)
What if i need to get the image of whole Monitor screen...not only a vi front panel....
Message 6 of 13
(10,158 Views)
Hi nxt,
see Mikes answer. After simulating the PrtScr key you can read the clipboard to get the picture...
Message 7 of 13
(10,151 Views)
See mike's reply here
Ok mike beat me to this. I think ben will be happy to hear this but tags are useful afterall.. :smileyvery-happy:
Message Edited by muks on 08-27-2009 05:00 PM
Message 9 of 13
(10,146 Views)
You can click the Kudos & appreciate the people who have helped you. Smiley Happy
Does the minimum 50-post rule exist still?
- Partha ( CLD until Oct 2027 🙂 )
Message 10 of 13
(10,115 Views)
