command line script in LabView 2010 Win7
Hi guys,
How to execute a CL script in LabView 2010 and pass parameters to it?
(3,434 Views)
Hi JoVMo,
you can use the "SystemExec.vi". If you need to pass parameters, then you have to use quotation marks around the call.
Mike
(3,426 Views)
Where can I find examples to use this .vi? Like passing arguments to enviroment variables.
(3,396 Views)
Hi JoVMo,
you'll find it in the connectivity section. If you need some other functions and you don't know where it is, then you can search it. Click on the search button in the function palette from the blockdiagram.
Hope it helps.
Mike
(3,392 Views)
Ah, I forgot NI has an example database. 🙂
(3,385 Views)
