combo box to signal waveform
hello,
i would like to ask on how to connect the combo box to get the three choices of waveform signals like sine, bar & triangular. i tried to do it but the error is no connection. is there any other commands/ buttons to add to make the connection right? and i would also tried to have a counter when the trigger is off or on. actually, im its trying to create a simple waveform generator and still striving to learn the Labview.
Hope somebody can help me. or share some samples.
Thank you very much.
ai
(3,031 Views)
Have you been through the tutorials? Basically you want to have a case structure with a case for each type of signal to generate. The control (I would recommend an enumeration rather than a combo box) selects which case gets executed.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,028 Views)
