combo box + push button click event
I have three questions about the attached vi  (not completed ,and assume the subvi(read HAL file is working ) :
1) why at run time i can't click on the arrow of the combo box  , even though they are filled by values
2)How do i create a click event in lab view . i.e i want to read the combo box value and the numeric control value only when i push the button that is next to them .
3) I want the application to run forever (unless i push some exit button) . Does this mean that all the applications in LabView are "under" a big while loop ???
(4,187 Views)
Attach also the sub vi .
P.S :
I only have version 7.0 ...
(4,182 Views)
1 :- Make your combo box control instead of indicator from shortcut menu.
2,3 :- Hope that , the attached vi is functionally same as you want.
(4,179 Views)
hi,
1. Change the combo box to control
2. In your case you can simple use a "case structure" and connect the button.
3. Its not necessary to put a "big while loop" however use the while loop in the last sequence and give a stop button to terminate the loop.
(4,178 Views)
hi,
(4,176 Views)
Thanks  guys.
helped a lot
(4,169 Views)
