column width in append table to report.vi
Dear All,
       Is there any way to set the different width for every column? Using the "append table to report.vi" can only set the same width for every column, which is not convenient.
      Thanks.
Hugo
(2,838 Views)
I don't think there is a way but you can try and use the append user formatted html to report.vi if you want to use your own HTML code.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(2,804 Views)
