color scale into matlab
I'm new to LabView and I have a simple question: someone sent me a vi with a colorbar, with blue at 90% and red at 100%. I have some plots in matlab that I want using the same color scale. While I can use a similar blue to red graduated color bar in matlab, the exact shades seem to be a bit different. Is there a way I can extract the lookup table that relates intensity to color and import this into matlab?
(4,426 Views)
Hi Kid Lu,
Here is a great document for how to get access to the color markers used on an intensity graph: http://digital.ni.com/public.nsf/allkb/1ADFF221E27F5B5886256E6F007C7B58?OpenDocument
You can either right click the # on the right side of the intensity graph and go to marker color to see the exact RGB values, or use a Zscale.MarkerVal[] property node to read from the intensity graph its current color settings pragmatically.
Stephen B
(4,390 Views)
Much appreciated! I figured it out eventually, but I had to do some reading as I didn't know the first thing about anything. Anyways, I finally figured out that the shading of the z scale was determined by a color table, which was actually a 1d array of colors. I probably didn't do it the smartest way, but I ended up using division and modulo arithmetic to get at the individual RGB values of each color and put that data in a 2d array which I then wrote into a CSV file.
(4,376 Views)
