color match template
i am attempting to create a color match templte from within a VI and then save it to a png file
The trouble is it simply saves the image without any ofthe matching parameters, as if it's not learning the template, simple saving an image
The only way i have been able to save a template is using vision assistant
any ideas?
(3,150 Views)
To add :-
I'm Carring out color patern matching based on a vi found in the examples folder,
color pattern matching.vi
(3,143 Views)
Hello..
I am also facing the same problem. If you got the solution then please share with me.
Thank You.
(2,734 Views)
