collect all subvi's in a hierarchy for a VI
i would like to collect all the subVIs in my hierarchy into one directory or .llb so that i can easily store and copy my VI for other users.  what is the easiest way to collect all my subvi's?  it seems like a simple thing that is done often, but i just can't find it on any menus.  i don't need to make an executable for distribution, just make sure i have all my subvi's in one place.
thanks,
dan
Message Edited by dhoopes on 08-26-2005 10:45 AM
(3,205 Views)
Select Menu->File->Save with options. Choose suitable mode. For example "Development distribution". Save project.
Jack
Win XP
LabVIEW 6.1, 7.0, 7.1, LabWindows/ CVI 7.1
Let us speek Russian 🙂
(3,199 Views)
And a word of warning. If you use an llb to save VIs in development, a single corrupt VI can cause the entire llb to be unreadable. Backup often the llb or convert the llb back to a folder with individual VIs using the VI Library Manager (still do a backup of the VIs).
(3,192 Views)
I'd like to second Dennis's suggestion.  You only have to loose EVERYTHING once to realize how painful it is.  I typically back up the llb to a new filename at least daily or when ever I have made a significant change (got a sticky bug worked out or a feature finally working).
Good Luck,
Bob Young
(3,181 Views)
how do i use the VI library manager to get it back to a directory?
thanks for the help,
dan
(3,170 Views)
The VI library manager can be found in the tools menu and it has two relevant buttons: "Directory to LLB" and "LLB to Directory". In this case, you want the second one.
___________________
Try to take over the world!
(3,157 Views)
