coding program problem
hi...i ma doing a program in Labview 6.1.(evaluation) i got windows xp. the concept is very simple. i will generate various siganls like sine. cos etc waves with different phases, amplitudes and will add them so create a complex waveform. then with this waveform i will do stuff like time and frequency,FFT, wavelets etc. can u suggest me the steps with some explanation to do this? also i have problem in adding wavaforms( i am not finding anything to add waveforms directly) ...can u suggest me some tips?
pls mail me ASAP..i am waiting
also i am having
(2,482 Views)
If you are using the waveform functions you can add them together using the add waveforms function find under:
Functions -> Waveforms -> Waveform operations
Generating the waveforms and analyzing them can be done using the different waveform functions on the Analyze palette.
If you in LabVIEW go Help -> Find Examples -> Search...and search for waveforms you will find a bunch of nice examples (not absolutely sure what is included in the evaluation package though...searching here on the zone is an alternative..).
(2,482 Views)
