code works until I build exe
Have you tried compiling with debugging enabled and using the remote debugger?
The remote debugger allows you to run the exe on your target system and follow along in the block diagram on your development station, so you can see where your exe is hanging.
=== Engineer Ambiguously ===
Message 11 of 16
(1,660 Views)
Not yet...thanks for bringing it up earlier, I didn't know it existed...I will try that now.
Message 12 of 16
(1,657 Views)
Search in help for "Building and Distributing Applications" and read the section on Debugging Applications and Shared Libraries to see how to use the remote debuger
Message 13 of 16
(1,648 Views)
Gee, I somehow missed your statement on this thread that you are now trying to run the exe on the same pc. Can you highlight where you originally started that?
Message 14 of 16
(1,630 Views)
First post, point number 2.
Message 15 of 16
(1,621 Views)
Sorry, you are correct. I had the coworker mention from your original post stuck in my head.
Message 16 of 16
(1,616 Views)
