Yes, you will be able to build a DLL from a VI in LabVIEW, however, you need the professional version to do that ( https://www.ni.com/en/shop/labview/select-edition.html ) or the "application builder"( https://www.ni.com/en-us/shop/product/labview-application-builder-module.html ).
You will find information on LabVIEW help: application builder >> building a shared library.
I suggest that you use a string as the input of the dll and an array of strings as the output of the dll.
You can use the functions "string to path" and "path to string".
