closing suddenly problem
Hi all,
When i working on Labview for  developing someting, the labview is closing suddenly without any attention.
This issue is being seen all of Labview version (8.x, 2009 SP1 ect.)
Message 1 of 11
(4,455 Views)
Are you seeing it with the same code or with different code?
Are you seeing in on a single PC or on multiple PCs?
Message 2 of 11
(4,451 Views)
It's on Multiple or on any PC and different code
Message 3 of 11
(4,448 Views)
Actually if i use different vi, no problem. This is on the  just one vi.
I think is a user interface design problem because of if i change the code in this vi, problem conti..
Message 4 of 11
(4,440 Views)
Hi, can you post your VI.
LabVIEW 8.2,8.6,2009...still learning 😛
Message 5 of 11
(4,436 Views)
Message 6 of 11
(4,430 Views)
no any info ??
Message 7 of 11
(4,391 Views)
You are right.
There is something wrong with that vi.  I could open it, but as soon as I tried to see the block diagram, it killed LabVIEW.
Do you have a backup copy of that VI?  I doubt that you'll be able to do much.  Unless customer support at NI could have a look at it.
R
Message 8 of 11
(4,380 Views)
Thank you, so that i m waiting support from NI !!!
Message 9 of 11
(4,374 Views)
thank you all. I have solved this issue.
Message 10 of 11
(4,333 Views)
