close vi and open again from a subvi
My problem is:
I want to close the vi(1) in the subvi (2). How Can I close the vi(1) in my subvi(2) if vi(1) has called my subvi(2)? In my subvi(2) I need to close the vi (2) that has called the subvi (2) where I am now, and then, when I close the vi (1), I want to open the vi(1) (front panel) again when I press a button of my subvi(2). How Can I do it?
ToNi.
Message 1 of 8
(3,634 Views)
This example shows the basic code for a VI to call
another VI and closes itself.
Version: LabVIEW 7.0
Cheers!
Ian F
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 2 of 8
(3,618 Views)
Hi Ian
Nice code.
I posted some examples in another thread to the same topic started by ToNi, but I had problems to start the first vi after closing the second vi.
But just a little advice - if you use the Run VI function, wire a true-constant to Auto Dispose Ref. If you do not, you may keep unnecessary references in memory.
Just if you did not already know this. 😉
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 3 of 8
(3,614 Views)
Nice reminder, Thomas 😛
Cheers!
ian f koo
Ian F
依恩与LabVIEW
Message 4 of 8
(3,608 Views)
Thanks very much, but I doesn't works because of in your block diagram, between open vi reference block and FP. Open property I put a call by reference node because I need to pass parameters to the subvi(2) from my vi(1) and then, when I call subvi(2) from my vi(1), vi(1) doesn't close and when I call vi(1) from my subvi(2) an error ocurrs (Modificar_pla_de_treball.vi is my vi(1) and Actualitzar_Pla_Treball.vi is my subvi(2)):
Error 1000 occurred at Open VI Reference in Actualitzar_Pla_Treball.vi->Modificar_pla_de_treball.vi
Possible reason(s):
LabVIEW: The VI is not in a state compatible with this operation.
because the vi(1) is still open.
How can I pass parameters to my subvi(2) using your diagram block?
Thanks, very much
ToNi.
Message 5 of 8
(3,587 Views)
Possible reason(s):
Thanks, very much
ToNi.
Message 6 of 8
(3,584 Views)
Hi again,
I think the problem is the following:
When I launch a subvi from a vi using a call by reference node, how can I tell it I am not interesting in wait until done? similar to invoke Method:run VI where I can set wait until done to false.
ToNi.
Message 7 of 8
(3,572 Views)
Hi ToNi
Do you really have to close the vi's?
I don't want to force you to use the state-property (there's an example in your other thread to the same question), but I think you can avoid some problems.
Just have a try.
Thomas
Using LV8.0
Message 8 of 8
(3,563 Views)
