close slowly for front panel
I used the close panel invoke node to exit a built application.
But I found the closing is slow a little bit.
I can observe two icons in stopping the application.
Can you tell me how to avoid this slow speed of closing FP?
(Quit Labview.vi also shows the same speed with closing FP)
Message 1 of 23
(4,115 Views)
Do you have any other part of the code still running after you close your FP? The tray icon will still show until all code has finished executing even if your interface VI has closed.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 2 of 23
(4,100 Views)
You do open a new VI ref just to close it's front panel down, that seems quite unnecessary.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 23
(4,064 Views)
Thanks, James.Morriƽ
The closing part is the last code (after killing some queues) in my block diagram.
Do you have no any other delay  I saw?
Message 4 of 23
(4,025 Views)
Thanks, Yamaeda.
How did you kill the application without quit labview.vi or new VI ref?
Message 5 of 23
(4,021 Views)
You don't actually have to wire references into the App.Kind or the VI.FP.Close Nodes.
Message 6 of 23
(4,009 Views)
George Zou
Message 7 of 23
(4,006 Views)
@zou wrote:
You don't even need the App Kind property node...
Message 8 of 23
(3,979 Views)
You don't kill it.  You make it so that all VIs complete and you close all front panels that were opened.
Message 9 of 23
(3,974 Views)
crossrulz,
so, is it natural to shut down slowly or is there any other way to shut down?
Message 10 of 23
(3,936 Views)
