close and reopen serial port with other baud rate
Hi LabVIEWers,
In my project I have to send a kind of kernel to a device, via RS232 with 19200 baud.
Then I have to start the kernel (sending an ´S´ to the device, still with 19200 baud.
After this point I have to change the baudrate to 115200, and with this baudrate continue the communication. After speed change I send a "P" character to the device (a kind of ping), and the device should respond with 0x55. Normally this vi doesn´t work. BUT....
...if I set a breakpoint before the speedchange -> start the vi and wait until it comes to the breakpoint -> click CONTINUE on toolbar, ans IT WORKS! When I remove the breakpoint, it doesn´t work. I have tested this 100 times, this is reproducable.
I already tried to insert a wait instead of the breakpoint, but it doesn´t help.
What should be the problem?
regards
MB
(3,434 Views)
Hi!
Please send your vi, so we can get clear idea (about sequence 0,1,2..).
Whay everytime you are configuring serial port before writing and reding charcters???
(3,429 Views)
Clearly, the device needs time to receive the S, react and reset its own baud rate. I can't see a reason why it should not work with a proper delay in the false case. How long did you wait?
Paolo
(3,417 Views)
interlinked
- Partha ( CLD until Oct 2027 🙂 )
(3,388 Views)
Sorry, this one here.
(3,383 Views)
Hi Parthabe,
   seems that you interlinked too Smiley Very Happy
graziano
(3,372 Views)
Hi!
   the title of your post let me think that you opened and closed properly VISA port.... now that I see the code (even if as image) I'd suggest to close and open VISA in place of the breakpoint.  With my VI it works.
graziano
(3,370 Views)
