clear xy graph...
Does anyone know how to clear xy graph
at the beginning of a new run?
To me, the old graph stays on until next
update. But I really wish I could clear
that up when I hit execution button.
Thanks...
K.C.
(3,723 Views)
Hi Kchen,
ou can create a local variable to that XY graph and then in the begining of your program you wire a cluster constant (all zeros). That would clear the stuff from the graph. hope this makes sense.
A Rafiq
(3,723 Views)
An example of this can be found by following the Resource Library menu to LabVIEW, then User Interface, then Graphing/Plotting, then How to Clear Charts and Graphs. It suggests loading the History Data property of the chart or graph with all zeros at the completion of the vi. I was struggling with the same issue just this morning. I gave this a try and it works beautifully. Good Luck.
(3,723 Views)
use
if u r using NI GRAPH THEN
USE
cwgraph1.cleardata
IT WILL CLEAR THE GRAPH
(3,723 Views)
hi
while searching for my problem of clearing graph,
i got your ans.
i am very new to labView,i have labview7
i don't understand
what is this
cwgraph1.cleardata
please give tell me indetail
thanks in advance
shital
(3,723 Views)
it's just a property node. like if you were to run a macro then look at the code for it. this is what it would look like. Just do what A rafiq said and you'll be fine.
Joe.
"NOTHING IS EVER EASY"
(3,723 Views)
