clear the history of xy graph
I am having difficulty to delete/reset the history of xy graph. My VI  and the needed subVI are attached..Any ideas would be appreciated
I tried three different ways: Connect the graph to a constant; Use initialize invoke node, command the reset terminal in the Built-xy-Graph, but none works correctly!!!
thanks in advance
good day
Message 1 of 10
(6,001 Views)
Hi Abo,
I don't see any place where you even try to delete this history in your subVI!
You need to write empty arrays into those shift registers holding your 1D arrays as they store your data…
Main problem here: THINK DATAFLOW!
It doesn't make sense to empty the data sink when the data source still holds the history!
Message 2 of 10
(5,986 Views)
Accepted by topic author AboHareth
Actually, the initial reset is made three time, but none of them is really needed, as the graph is immediately filled with other data. The problem is that you keep adding elements to the arrays in the shift registers of the sub-vi.
Reset the shift registers content when the sub-vi is executed for the first time.
Paolo
Message 3 of 10
(5,977 Views)
Hi GridW
you notice that the loop inside the subVI  will be executed only once, thus connecting the shift register to a zero would result in not remembering any old values and thus no graph will be shown (if you give it a shot, you will see). I actually need the history when VI is running, I only need to forgot it at the first iteration of the loop in the main VI which would allow the reset.
It doesn't make sense to empty the data sink when the data source still holds the history!.
I see  my mistake, but still I have no idea how to reset the data source
thanx
Message 4 of 10
(5,965 Views)
@pincpanter
 HI, pincpanter,
First, I marked you answer as a solution by mistake. I do not know who to cancel that!!
As i just said the subVI executes only once allowing us to remember old values. this resetting them result is no output for the VI
thanks
Message 5 of 10
(5,962 Views)
Hi Abo,
Yes, I know this.
You need to put some "reset" code inside this subVI. Whenever a reset-condition is met (either first run or an additional input) you need to write an empty array into the shift register!
A good place would be the case where you output an empty graph from your subVI…
As an example you could examine several of those Point-By-Point functions (in signal analysis palette), they most often also have an Reset (or Init) input!
Message 6 of 10
(5,955 Views)
Hi GerdW,
I am sorry but I really can not see what you are saying is correct. I think resetting the shift register under any condition is not a solution, since it executes only once then there is no way we get a history if we reset it?!!
Can you please examine you idea in the VI?
thanks
Message 7 of 10
(5,952 Views)
It does not execute once. It executes repeatedly until you press STOP.
So, when the sub-vi is called the first time in the While Loop, you need to reset all shift registers.
Add a Reset boolean input to the sub-vi to do this. The input should be true only when the loop index is 0.
In pseudocode: Reset = (Loop index == 0).
Paolo
Message 8 of 10
(5,950 Views)
Hi Abo,
simple like this:
Message 9 of 10
(5,943 Views)
Thank you for your solution. I also did it in somehow similar way. it is attached for those how might have the same diffeculty
Message 10 of 10
(5,940 Views)
