clear memory of shift register after each run
hi
I am using a shift rergister in my Vi.I want to clear the shift register after execution of the Vi.Please help me in this
Certified LabVIEW Developer
(7,585 Views)
That's what the initialization should do. So connect an empty data to the entry of the shift register (in a loop it's outside on the left).
Software developer
www.mcm-electronics.com
PORTUGAL
(7,584 Views)
thanks for the reply
I have done that .My aim is to plot a real time graph, of position Vs voltage when a stage moves..Suppose stage moves from 20 to 50.then in next run it comes back from 50 to 20.But graph again plots from 20 to 50.If the first run is from 50 to 20 all the successive runs graph starts from 50.Is it due to shift register initialisation
warm regards
augustin
(7,572 Views)
HI again:
First i think that you should only acquire to an array. Check if all the data it's in the correct place.
Then you should check the graph. cause it might be only a visualization issue.
IF you want me to help you more, do me a small example  with offline data. So that i can run it here and see the problem happening. Then i will correct your code and send it to you again.
Tell me your labview version.
Software developer
PORTUGAL
(7,565 Views)
