clear indicator during the while loop
Hello guys,
I trying an application very easy to show a number of iteration ( or count  by encoder in second time) and show a partial and a total on two indicator.
I would like to reset the indicator and chart  when i press a clear button, but the only clean is the chart, while the indicator reset to zero rapidly ( with reinitialize to default value) but keep a memory of the iteration riched at the moment.
What kind of solution you can suggest me? ) I tried to use shift register, case structure but I can't find a solution
Thanks again for your precious help or suggest..
here  I posted my VI
(5,264 Views)
Try this out, is this what you looking for,
(5,245 Views)
I edited your vi to do what I think you want.
Tim
GHSP
(5,224 Views)
here there is a VI modified
Thank you Systemcrash, good suggest..
I tried to implementing your example( and suggest ) with my application  to acquire a counter ( I using an USB 6009 as prototype)  ,but I can't reset the counting.
My idea is obtain  a partial count  and total count.
So when I desire press a button reset or Clear and restart to zero on partial counter indicator  while the total must be the number of count acquired.
Thanks again for your precious help..
Dave
here I posted a Vi modified
(5,211 Views)
Accepted by topic author devil80
Here is the same thing I did with your counter stuff.
Tim
GHSP
(5,207 Views)
Hello Tim,
I tryed at home this VI, and doesn't work well as my requirements because when you press clear the total amount increase of the last measure counted, so i think the numeric function ( add) wired with a  previous count may be a  mistake,,
I modified a VI with a partial and total counter, and finally i can  reset the partial counter and the total counter    while the "while loop" is running..
I read several post on this forum and I understand that  is a common problem... 🙂  some post is :  you must  to use a stop task and start again , and I followed the advice..finding a correct solution for my application.
Here i posted my code modifyed
P.s  if you see improving code please inform me...
Thanks again for your help..  🙂
Dave
(5,190 Views)
