clear graph
I need to clear the attached graph run time pressing a button.
can some body help me.
Thanks in advance,
Ranjith
(3,907 Views)
Hi Ranjith,
there is nothing in your graph. Smiley Happy You can clear the graph if you connect an empty constant to it. Use a loop with a shift register, insert a case structure to it. create one case to clear your graph and one to acquire your data. Connect the reset button to the case structure.
Hope it helps.
Mike
Message Edited by MikeS81 on 07-07-2008 08:35 AM
(3,905 Views)
I got the solution myself.. if i clear with constant. i couldnt clear. i used intialize array concept to clear. it does work
Thanks for your response.
Ranjith
(3,901 Views)
Hi Ranjith,
attached is a short example and to clear the graph with a constant works. Smiley Wink
Mike
(3,896 Views)
Ranjith
As mentionned by Mike : a graph can be cleared by wiring an EMPTY array constant !
(3,895 Views)
