cleaning up multiple wires
Is there a way to clean up multiple wires in a block diagram at the same time.
Thank you,
(3,059 Views)
That is a feature which many have been after.  I think someone in the LAVA forums wrote a VI which did that, but it involves using unsupported features.  The main problem with that implementation (which the author notes) is that is just goes through one by one, and since the wire cleaning process is dependent on all the other wires and objects on the block diagram, simply cleaning them in order is not necessarily optimal.  In any event, general advice would be to try to keep things fairly clean as you code, and hopefully you won't have to clean up to many wires individually.
Best Regards,
JLS
Best,
JLS
Sixclear
(3,028 Views)
Hi to all!
It could be useful refer to this post
Cheers
Matteo
(2,874 Views)
Hi Matteo,
I wish to know why you have replied to a 2-yr old thread & linked a 4-yr old thread in it? Smiley Happy
That too, now, after the BD clean-up option has come in LV 8.6... Smiley Wink
- Partha ( CLD until Oct 2027 🙂 )
(2,839 Views)
