05-06-2006 05:15 AM
05-06-2006 01:45 PM
05-08-2006 11:17 AM
05-08-2006 11:22 AM
05-08-2006 11:46 AM
If you could highlight execution in the program where it works and find the part of the program that is causing the pop-up that would be extreamly helpful. That way you can see any potential differences in constants etc, that might be causing the issue. If you do find the difference and it is still not working, try deleting everything away from the larger program except what is causing pop up and see if it still works. If it does just save that VI under a different name and post the working and non-working VIs for us to look at. Thanks
Tyler H.
05-08-2006 12:14 PM
05-09-2006 09:50 AM
