chnaging input in a waveform graph from front panel in labview
Hi !
I am working with temperature sensors; I have several sensors to read simultaneously.
I want to plot information from different sensors in different plots and have the option to change/select  the sensors in the a graph from front panel. For example, I have 8 sensors(please see the attachments_ front panel), A,B,C,D,E,F,G and M. Some time it could be possible that user want A,B,C in Tumor Graph or sometimes only A and B. That means the identity and the number of sensors could be changed in different times.
Now I connect only two sensors per graph (ref: block diagram) but the number and the sensors to be plotted in a certain graph can be changed, so How can I implement it ?
Any help or idea will be appreciated.
Best Regards,
Hasan Masud
CTH, Sweden.
(2,656 Views)
Hi hasanma,
Well, you could expend the build array and add more inputs to it as shown below:
And individually select which sensor data the user wants to view as shown below:
Warmest regards,
Lennard.C
Learning new things everyday...
(2,493 Views)
