check status
After downloading and installing the WT9100.zip folder from NI i came across those errors when I loaded the initialize.vi
"check status.vi " and "default instrument setup.vi" . ( unable to find them )
Any suggestions where to find them. All is loaded in the .LIB folder. LV8.2
Paul
(4,691 Views)
They are in the _wt9100.llb file. Did you copy the entire wt9100 folder into the instr.lib folder? If you did, I think it should have automatically found them. If you put them someplace else, you just have to point to the files when asked.
(4,681 Views)
Dennis,
I will re-install the driver tomorrow when i'm back at work as i'm sure i extracted all the files to the same folder in .llb.
I will keep you informed here on this thread.
Pol
(4,667 Views)
Accepted by topic author PvW
Just to be absolutely clear, when you unzip, you will get a folder called wt9100 with two llbs in it. Paste this folder to LabVIEW 8.2\instr.lib. Restart LabVIEW.
(4,659 Views)
Dennis,
I removed the driver and reinstalled it.  It worked this time.
Thanks for your quick response.
P.
(4,643 Views)
Hi.
I have a problem, I use VI and designed to control a Fluke 9100 calibrator, but when I run the VI, the time the program expires and will not let me see the data sent. How can I make this more prolonged period, or enable and disable it when I want. Thank a lot!
(Hola. Tengo un problema, quiero utilizar el VI ya diseñado para controlar un calibrador Fluke 9100, pero cuando corro el VI, el tiempo en el programa expira y no me deja observar el dato que envié. Como puedo hacer mas prolongado ese periodo o bien, poder habilitarlo y deshabilitarlo cuando yo quiera. Muchas Gracias.! )
Message Edited by randy21 on 08-03-2009 02:25 PM
(4,364 Views)
