check a value for string
hi need help.
let say the user is inserting a value 012333333
how to check there is no alphabet was entered by the user?
(2,814 Views)
Hi jeyanthi,
you can use the "match pattern" function. Search for strings and if the "offset past match" is -1, then there is no string in it.
Mike
Message Edited by MikeS81 on 06-05-2008 07:18 AM
(2,813 Views)
thk u Mike
(2,802 Views)
In the Comparison palette is a function called Lexical Class. It will tell whether a character is numeric, upper case, lower case, white space, and a few other categories. It only works on one character at a time so you would need to loop through your input string.
Lynn
(2,781 Views)
