chart array elements separately
Labview forum,
I have a for loop which produces an array of 2 elements.
This is contained within an outer loop.  Inside the outer loop, I have connected the array to a chart function.  For each outer loop iteration, the the chart plots both array elements as sequential elements in the same plot.  This was not the behaviour I wanted.
Instead, with each outer loop increment, I would like each array element to be added to a separate curve on the same chart axes.  Thus, in this case, two curves would be plotted simultaneously.
How can I achieve this?
Attached is a simple example of my current situation.
Jamie
Message Edited by Jamieg on 09-17-2007 06:45 AM
Using Labview version 8.0
(5,240 Views)
Jamie,
here a possible solution:
hope this helps,
Norbert B.
Message Edited by Norbert B on 09-17-2007 07:52 AM
Norbert
Expert: Geometry
(5,223 Views)
Hi Jamie,
I hope that your problem might ve been solved by Norbert's suggestion.
But please dont post duplicate copies of attachments.
- Partha ( CLD until Oct 2027 🙂 )
(5,210 Views)
An alternative solution uses the "array to cluster" function. (Don't forget to set the cluster size!)
Message Edited by altenbach on 09-17-2007 07:50 AM
(5,204 Views)
Thanks for your help Norbert and Altenbach.
I knew it would be something simple.
It is strange, though, that with Norbert's suggestion we logically convert the 1-dimensional array into a "2-dimensional" array even though that "2-dimensional array" still only has one dimension of data.
Jamie
Message Edited by Jamieg on 09-17-2007 08:38 PM
(5,181 Views)
No, it has two dimensions, one of the dimensions is size 1, though 🙂
You can even have a 1D array of size 0 and a 2D array of size 0 x 0, for example. Not the same!
(5,171 Views)
