charecter to hex
Hi
i want to conver string to hex
what i mean i want to convert "wisam" it string that i want to cover it to hex
how can i do that in labview
thanks
(2,974 Views)
Hi
check the  attached file
(2,969 Views)
(2,968 Views)
Hi
can you save the file so i can open it with labview v2009
thanks
(2,958 Views)
(2,954 Views)
If you want the Hex values, you can use the first portion of the code from Zekasa and set the display to Hexadecimal.
That way, it is still a numeric but you see it as Hexadecimal.
In other words, all you need is the "String to Byte Array" function.
(2,926 Views)
