changing value when reading from file
When I am reading from a text tab-delimited file labview is returning a changed value. For example, the value should be 337478.47 but labview is returning 336727. I have tried changing the array to EXT, it is currently DBL, and that didnt seem to change anything.
I am using LabView 8.
(2,673 Views)
Your numbers are fine. Just right-click on your indicators and select the desired format and precision. (By default, it only shows 6 significant digits).
See if this works. 😄
(2,667 Views)
Thanks, that was it.
I can't believe it was something so simple, but then again it is usually the simple things that do your head in the most. 🙂
(2,664 Views)
