changing the x axis
Hi everyone.
I have done an fft in lab view signal express, but the x axis shows the frequency (Hz).
I need it to show the range.
I have the formulae to change the x axis, but i am not sure on how this can be done!.
the formuale is range = freq *c*dT/(2*dF)
Where dT = 0.02
and dF = 66*10^6
c = 3*10*8.
how can i get the range on the x axis.
many thanks.
Message 1 of 14
(4,471 Views)
Right-click the graph and select Properties.
Then go to the Scales tab.
The drop down box shows by default the X-axis, so that's ok 🙂
If you need another scale, select it first.
On the same tab you also see Scaling factors Offset & Multiplier.
Calculate both to convert what you have now to what you want
I won't do the math's for you 😞
Enter the two values and
Then click the Ok button.
Message 2 of 14
(4,465 Views)
Hi Many thank for your reply. Was very kind of you. you said in your post
"On the same tab you also see Scaling factors Offset & Multiplier"
But i cant see this when i click the scales tab....  😞
Message 3 of 14
(4,460 Views)
So you mean your Scales tab doesn't look like this one:
Message 4 of 14
(4,456 Views)
Hi. No it is not the same. similar, except mine does not show the scaling factors or the inverted checkbox.
Although it does have a 'Timestamp Type'
Message 5 of 14
(4,454 Views)
What LV version do you use?
Can you post your vi?
Message 6 of 14
(4,452 Views)
what do u mean by vi. im sorry, but im a newbi to labview
the labview version is
LabView Signal Express, version 3.00
Installed applications
-DAQ Assistant
-Signal Express Components
Message 7 of 14
(4,449 Views)
I'm sorry but I overlooked the "Signal Express" part in your original post 😞
Anyway, I openend SE and in the Scales tab I still have "Scaling factors" Offset & Multiplier
Message 8 of 14
(4,424 Views)
hmmmm, strange... not sure why mine does  not show it..
is there another way around it?
Message 9 of 14
(4,419 Views)
which version of Labview SE are you running?
Message 10 of 14
(4,387 Views)
