changing the speed of Ethernet Link of the PC to 10 or 100 MBPS
I need to change Ethernet Speed of the PC programmatically that is change the Speed to either 10 or 100 mbps.
Is it possible, If yes , then please let me know the procedure.
Or atleast I should be able to read the PC Ethernet speed in LabVIEW.
(3,457 Views)
You can read it with some .net help.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(3,426 Views)
Thank you. I have installed Dot Net Framework 4.0 , but I do not get this System.Net.NetworkInformation.NetworkInterface in my Active X selection.
I dont know if I have to install something additional.
(3,386 Views)
Accepted by topic author Hemagopal
You dont need .net 4.0 for this (.net 2.0 is good enough) or anything else installed.
I have attached a VI with the control.
PS: If you need to load .net 4.0 assemblies in to LabVIEW, you need to follow instructions in this link:
http://digital.ni.com/public.nsf/allkb/32B0BA28A72AA87D8625782600737DE9
(3,364 Views)
How can i chane the speed of my NIC  problematically from labview
(2,676 Views)
